Are there any reverse design fans? What i mean by this reverse fan blades, pushing air to opposite direction compared to normal fans.
I want such fans purely for aesthetic reasons, i dont care at all if those fans would be less effective.
Fans dont need be RGB as i have Halos Frames in my next buid, that build will only happen if i can find the fans.
I faintly remember some CES 2019 video had some similar style fans in display but i dont remember what it was.
"Game" : Work in Progress
"Work" : Threadripper 3970X | Gigabyte TRX40 Designare | 128GB G.Skill Trident Z Neo 3600 CL16 | Gigabyte RTX 2080 Ti Xtreme Waterforce WB | Custom Loop | Intel X520-T2 Dual 10GbE NIC
Dell R710 NAS : 2 x X5660 Xeon | 96GB DDR3 ECC | Intel X520-T2 Dual 10GbE NIC | 6 x 16TB Seagate Exos X16 | Dual 1TB Kingston NVMe as Cache | IBM M1015 flashed IT-mode | Proxmox
HP ML350P : 2 x Xeon E5 4650 | 128Gb DDR3 ECC | Intel X520-T2 Dual 10GbE NIC | Quadro K6000 | 8 x Samsung SM1625 800Gb SSD | 240Gb Intel D3-S4610 Boot | Dual 1TB Samsung 970 Pro | IBM M1015 flashed IT-mode | Dual 750W PSU
https://linustechtips.com/topic/1021507-reverse-design-fans/
Yes - they do exist. I believe they're sometimes seen on dual-tower coolers? However, I can't remember what the cooler was.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192669
I think i found one cooler that has it but cannot find any of those fans anywhere, i dont want to buy 3 coolers to get 3 fans.
Its CoolerMaster MasterAir MA410M
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192714
I'm not sure what you mean. The cooler uses standard case fans.
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192730
Well i checked one review and it clearly has one fan that is pushing to reverse direction.
Also in this image one fan is clearly reverse design.
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192737
Wow, I never noticed until now. Deepcool has their MF120 fans: http://www.gamerstorm.com/product/CASEFAN/2018-02/1289_7712.shtml
I don't think you'll be able to find standalone fans with both a normal and reversed version though.
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192753
I need the fans as side intake to Lian-Li PC-O11 Air, pulling air from 360mm radiator.
I already have 6 Halos frames coming with white 120mm fans and i also have 3xCorsair SP120's pushing air to the radiator so its going to be push+pull configuration.
Those deepcool ones arent quite what im looking for.
I could probably sell the coolers easelly off tough after removing that one fan if i would go buy the coolers.
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192775
That's actually non-standard since the flow for fans should be going through the blades and past the X shaped frame that holds the motor mount. I see why they would have done it for the RGB aesthetic but other than trying to reach them directly to see if they are willing to sell you some.
The only reversible fan per say I've ever seen are these from silverstone.
http://www.dvtests.com/silverstone-fhp141-vf-test-and-review/
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192805
That could be the fan, even tough im not fond of its desing. Ill take look and see if i can find 120mm version of that.
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192829
I don't believe they made one in the 120mm variant it was a very niche product as it was since this was an extra thick fan(38mm).
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192846
Oh you're in luck apparently zalman made a fan with the reverse flow direction same as the coolermaster ones:
http://www.zalman.com/contents/products/view.html?no=75
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192864
Exactly what im looking for.. now to find it in local stores
https://linustechtips.com/topic/1021507-reverse-design-fans/#findComment-12192981
