So I’m learning Trig right now, I’m getting better at Sin Cos and Tan, just learned those today, but I’m stuck on this problem, I’m not asking for the answer, just how to do it
I have to find X using the angle and the side I’m given, we never learned about this in class (we just did Sin Cos Tan today)
how is do I do this? Please help I need to get a good grade in this class
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1021480-i-need-help-in-trig/
2 minutes ago, iLostMyXbox21 said:
<snip>
We can help explain but we cannot give you the answer.
Just be aware of this.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192362
I know :::
All I want is help, because I still need to know how to do it and asking for the answer is not learning anything
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192365
To point you in the right direction you might want to label each side and then wright out sin cosine and tangent as ratios of the sides.
Also, congrats for your attitude, if you keep on going like this you should be able to get a good grade in the class.
Edit: Here is a picture:
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192385
2 minutes ago, Arika S said:
did you learn SOH CAH TOA? it's based on what details you already know and what you need to find
SOH. Sine: sin(θ) = Opposite / Hypotenuse
CAH:  Cosine: cos(θ) = Adjacent / Hypotenuse
TOA: Tangent: tan(θ) = Opposite / Adjacent
You need to find the Opposite and you know the Hypotenuse, so you would use _______ ?
So Sin..
yeah we learned SohCahToa
but I still don’t get it...
ive never been more confused about a 3 sided shape..
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192401
5 minutes ago, Arika S said:
ok i'll start you off
sin(28°) = X÷19
Uhhhhhhh
ill just work on a different assignment and ask my teacher tomorrow this is confusing
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192430
1 minute ago, Arika S said:
either they didn't actually teach you anything or you didn't pay attention, this is the basic of basic for trig.
True, however it kind of is a hard problem for day one, or at least harder than the first problems I saw.
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192442
Well i was paying attention, and I don’t remember learning about this part, all we learned about was Soh Cah Toa
https://linustechtips.com/topic/1021480-i-need-help-in-trig/#findComment-12192456
