Ok i will try make this as short as possible so before xmas my mobo (Asus Crosshair V Formula -z) died so i got an RMA received a new one on the 10th of jan, to then find out my cpu (AMD FX 8350) had also died so i brought a new one and received it on the 12th and went ahead put it all together and it worked until yesterday 13th it BSOD in the middle of a LoL game got back on carried on but after the game i checked some things out.
Full System specs
Amd 8350 @ 4.3
16gb Crucial sport RAM
GTX 780
120gb Kingston ssd
1tb storage
Corsair AX760
Corsair H80
I did memtest 86+ to make sure there was nothing wrong there it did 3 passes no errors
i then did prime 95 and the log below
[Tue Jan 14 05:08:11 2014]
Self-test 28K passed!
[Tue Jan 14 05:23:11 2014]
Self-test 8K passed!
FATAL ERROR: Rounding was 0.46875, expected less than 0.4
Hardware failure detected, consult stress.txt file.
[Tue Jan 14 05:38:54 2014]
Self-test 40K passed!
[Tue Jan 14 05:54:26 2014]
Self-test 12K passed!
[Tue Jan 14 06:09:58 2014]
Self-test 56K passed!
[Tue Jan 14 06:25:18 2014]
Self-test 20K passed!
[Tue Jan 14 06:41:07 2014]
Self-test 32K passed!
FATAL ERROR: Final result was FA4C02A4, expected: 294EB549.
[Tue Jan 14 06:56:40 2014]
Self-test 10K passed!
[Tue Jan 14 07:11:45 2014]
Self-test 48K passed!
[Tue Jan 14 07:26:50 2014]
Self-test 16K passed!
[Tue Jan 14 07:42:04 2014]
Self-test 64K passed!
[Tue Jan 14 07:57:44 2014]
Self-test 24K passed!
[Tue Jan 14 08:13:19 2014]
[Tue Jan 14 08:18:42 2014]
[Tue Jan 14 08:28:49 2014]
[Tue Jan 14 08:34:08 2014]
[Tue Jan 14 08:44:27 2014]
[Tue Jan 14 08:49:47 2014]
[Tue Jan 14 09:00:12 2014]
[Tue Jan 14 09:05:37 2014]
[Tue Jan 14 09:16:24 2014]
[Tue Jan 14 09:21:59 2014]
[Tue Jan 14 09:32:16 2014]
[Tue Jan 14 09:37:22 2014]
[Tue Jan 14 09:47:35 2014]
[Tue Jan 14 09:52:46 2014]
[Tue Jan 14 10:03:07 2014]
[Tue Jan 14 10:08:43 2014]
[Tue Jan 14 10:18:33 2014]
[Tue Jan 14 10:24:11 2014]
[Tue Jan 14 10:34:16 2014]
[Tue Jan 14 10:40:18 2014]
[Tue Jan 14 10:49:58 2014]
[Tue Jan 14 10:55:36 2014]
[Tue Jan 14 11:05:20 2014]
[Tue Jan 14 11:10:51 2014]
[Tue Jan 14 11:20:50 2014]
[Tue Jan 14 11:27:49 2014]
[Tue Jan 14 11:36:23 2014]
[Tue Jan 14 11:42:56 2014]
[Tue Jan 14 11:51:33 2014]
[Tue Jan 14 11:58:45 2014]
[Tue Jan 14 12:07:08 2014]
[Tue Jan 14 12:14:00 2014]
[Tue Jan 14 12:22:35 2014]
[Tue Jan 14 12:30:31 2014]
[Tue Jan 14 12:38:26 2014]
[Tue Jan 14 12:46:14 2014]
[Tue Jan 14 12:54:05 2014]
[Tue Jan 14 13:02:29 2014]
[Tue Jan 14 13:09:27 2014]
[Tue Jan 14 13:17:50 2014]
[Tue Jan 14 13:25:09 2014]
[Tue Jan 14 13:34:20 2014]
So while this was happening i went to sleep woke up about 4  hours later and saw that 3 threads of the 8 were not running 1 stopped 6 min in or so  i believe i read then another 2 had stopped and different time 1:57 i think and about 3 hours into testing though did not show up in the log
i went back to sleep thinking that id wait for the logs upon waking up i see it had BSOD or something and it was sitting at login screen
im sort of at a loss here since there new parts
This P95 test was on Small FFt's
If i test on Blend this happens instantly http://prntscr.com/2japvi
[Tue Jan 14 16:50:06 2014]
FATAL ERROR: Rounding was 0.4921875, expected less than 0.4
FATAL ERROR: Resulting sum was 2.332281835502223e+016, expected: 2.332280461112699e+016
ERROR: ILLEGAL SUMOUT
Possible hardware failure, consult readme.txt file, restarting test.
Maximum number of warnings exceeded.
There was about 60 ERROR: ILLEGAL SUMOUT removed some to make this thread shorter
Hopefully someone has some sort of idear what could be going on here ? i have provided as much info as possible i have no BSOD dmps for some reason which makes it that bit harder.
https://linustechtips.com/topic/102135-help-with-cpuram/
i will give it a try if noone else offers a possible solution thanks
I just told you the solution.
Set your OC to manual.
Set FSB to 200 dont leave on Auto
Set your multi to give you 4.3 Ghz
Set your CPU voltage to 1.425
Set CPU LLC to Very high
https://linustechtips.com/topic/102135-help-with-cpuram/#findComment-1366134
It Seem to have worked thankyou do you think i could push the clock a bit on 1.45 now or should i leave it ? + temps are running around 50c now compaired to 37c  on full load
1.45 volts should take you to 4.5 or maybe even 4.6. It may go further with a balance of multi and FSB.
I guess I should make that FX OC guide I was thinking about doing.
https://linustechtips.com/topic/102135-help-with-cpuram/#findComment-1366355
