 How do I know if my cooler is installed properly? Also is it OK for Arik to maybe sag a little bit? Because it doesn’t seem like it’s sagging when I push up on it. It wants to stay where it is. Temps are actually great 60 under full load i7-7700K  pretty good for that chip.
https://linustechtips.com/topic/1021240-cpu-cooler-sag/
based on what you are saying it's likely to be installed correctly.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1021240-cpu-cooler-sag/#findComment-12189992
You have it installed correctly, I think that's what me and a few other people told you. It's just because of the extra fan. It should be fine. If you're really that worried try the fishing line thing to hold it up.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1021240-cpu-cooler-sag/#findComment-12190018
yes but im new to PCs. should it stay in place like this? on the sagy looking angle? will vibrations hurt it? or just me droping the case?
thanks so much btw!! im sorry, im new
https://linustechtips.com/topic/1021240-cpu-cooler-sag/#findComment-12190330
