12 hours ago, PolishedKarma13 said:
So, everybody, my computer will be sitting on the left side of my desk and I wanna be able to see the water cooling that is going to be in there. Work yall magic por favor
Corsair 600Q
Be Quiet dark base 700/900
Raijintek Thetis
Thermaltake g3
https://linustechtips.com/topic/1021073-need-an-inverted-case/#findComment-12189973
7 hours ago, Pyramiden said:
I own a black Corsair Air 240, which can be used in 3 orientations. I use it inverted.
It is also available in white, and there is the bigger Air 540 if you need more room.
You could also get a Thermaltake Core V21, but I found it to be too large.
Unfortunately im already using the core v21 and can say whole heartedly that I hate it but the other recommendations I'll take a look at.
https://linustechtips.com/topic/1021073-need-an-inverted-case/#findComment-12190726
Haha, I also hated it, and was happy when it was gone. I currently use the Air 240, which I really like, although it has big limitations in terms of GPU and CPU-cooler size.
https://linustechtips.com/topic/1021073-need-an-inverted-case/#findComment-12190741
