CPU_Fan Error
Solved by LogicalDrm,
What cooler? Check that something, preferably AIO pump or CPU fan is connected to CPU fan header. If that is, then check that fan is spinning or pump is working at startup. If they are, you can adjust warnings options in BIOS or disable if needed.
Ishikudeska ·
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3
play_circle_filled
Latest From ShortCircuit:
