New build starts up, shuts down for 2 seconds and restarts.
Solved by P4inkiller,
12 minutes ago, homeap5 said:It's your BIOS trying memory settings. Go to BIOS and set X.M.P., set some other settings to manual if needed and disable memory check if everything will be ok.
okey i just checked this was it, thanks. how do i close the thread?
Featured Topics
erico2304 ·
Posted in Troubleshooting0 -
aisle9 ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0
