 Hey so this is a very low-quality video to give you an idea of what the PC looks like. Doesn’t do it justice I promise.  Much lower quality in footage. What should be done to improve aesthetics? I’ve tried quite a few things, like cable management should I water cool?
thanks!!
https://linustechtips.com/topic/1020361-what-does-my-pc-need/
just describe the pc, no need to upload videos
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182641
You could just send pictures instead..
edit: actually videos are Better in a way
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182644
You say there is a very low quality video, where is it?  How about a complete list of your system parts?  A list of the parts in your system would go a long way as to figuring out whether to upgrade or not.  Also, include some system temps.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182647
Some blue lights....
and maybe sun glasses, they say looking at the sun isn’t good for your eyes
oh wait that’s just your pc
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182649
 No I mean aesthetically, it has an RTX 2080 8GB  running three monitors, it’s got enough power I think for now at least. I mean a statically what do you think you could use? Because it’s not perfect
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182650
Where should the blue go? Also lol come on
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182659
You could add a single strip under your pc and have it pulse or spin, it will add contrast, the red is kinda bland
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182664
Its very monolitic red, you can spice it up by giving white tone in the center.
get a white led stripe and put it under the gpu.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182665
 OK so I’ve done something like that this is a long time ago when my set up wasn’t as nice. Is this sort of what you mean?
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182675
i personally dont like mixing red and blue, i think its cheap looking.
blue led is cheap looking in general, but that just me.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182676
 OK that’s fair, so could I do like the bottom LEDs white? And everything else red? I really like red stuff
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182681
Yeah but too bright, it dominated the red.
it should be the undertone, since you want it to be dominant red.
theres a hole in the NZXT middle column, if that can be lit white, it will be nice.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182689
Ok so red on top white in bottom??
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182693
 Actually I can light everything red, and then just do the in NZXT logo white  like the 4 LEDs on the light strip under it.  Do you think it would look good?
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182698
That gpu power cable looks bad if you do it like that, why not having it from the top instead.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182704
Yeah it will looked better i think, everything red, but small details in white.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182706
16 minutes ago, JammyCreedog said:
Thats a nice setup. The interior of your tower could be spiced up with some rgb ram sticks. For desk lighting, i'd add some white led accents as underglow or as up-lights.
Yeah I’m thinking about that actually. But I have 32 GB of RAM and RGB sticks are expensive. There’s no way I would get new ram that isnt an upgrade.  I would need to get 64.  Or it’s not worth it in my mind. Because technology moves to quick. I have a OC RTX 2080 and it already almost can’t do 60 FPS 3 monitors. Which is scary considering it’s a new
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182765
What do you do on your pc that you need 32gb of ram let alone 64? In my opinion, any more than 16 on a primarily gaming system is a waste.  Keep in mind that after you purchase the rgb ram, you can resell your non rgb kit to recoup some moneys.
I'd play in windowed mode and shrink the window down a little to free up some fps in game.
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12182773
 Well because I have the best CPU on the market but now it’s not the best anymore...  didn’t take long. Technology moves to quick I remember when games only needed four gigs of RAM, then they said 8  now it’s 16  when does it end?
https://linustechtips.com/topic/1020361-what-does-my-pc-need/#findComment-12183645
