I would only upgrade if you are running out of ram in games and applications but Ryzen Cpu's like higher speed Ram not necessarily more ram (dont get me wrong more ram is always better but you would probably have better luck using higher speed ram)
Do i Recommend Ryzen? Yes. All of the Yes.
Main Rig Specs - BIG BOI
Ryzen 5 1600 @ 3.9Ghz
ASUS Gaming TUF B450 Micro-ATX
2x4Gb HyperX DDR4 @2133
GTX 1070 Founders Edition
Corsair Crystal 280X
500Gb SanDisk Sata SSD, 1Tb 7200RPM Hdd
EVGA 500 Watt 80+ Bronze
EKWB A240
