Whaaaat is going on?!?!?
Go to solution Solved by lukart,
PCPartPicker part list: https://pcpartpicker.com/list/hQGZCb
Price breakdown by merchant: https://pcpartpicker.com/list/hQGZCb/by_merchant/
CPU: AMD - Ryzen 7 1700X 3.4 GHz 8-Core Processor  ($190.88 @ OutletPC)
CPU Cooler: Corsair - H60 (2018) 57.2 CFM Liquid CPU Cooler  ($54.99 @ Newegg)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($76.00 @ Newegg Business)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($130.98 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($82.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8 GB Windforce OC Video Card  ($299.99 @ Newegg)
Case: Corsair - 200R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($57.89 @ OutletPC)
Total: $988.60
Generated by PCPartPicker 2019-01-12 22:10 EST-0500
This is the rig alone, not sure if 1500$ is for the rig alone or that inc the monitors. But 1000$ you have a really powerful work and game performance. and 500$ to spend on monitors. :)
Hello, I am a big EvE Online gamer and I am also a coding student that works as a freelance social media marketeer and have a small budget (student ). I would really like to build a 3 screen mid range setup that I can do those seamlessly with no problems and have room to grow with in that build. I know nothing of building a setup like you guys do and I am a very avid watcher of all your videos I know your very busy but any step by step help you can give I would be eternally grateful. I will deffinatly be giving shout outs on my forums and passing on the knowledge.
 Thank you,
         sincerely YouTube subscriber.
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/
You know that the ltt team is only hosting and sometimes moderating this forum? Or are you one of my three YouTube subscribers? :D
Welcome anyways to the forum, which is mostly filled by its community.
Budget, country and what with or without monitors and peripherals would be nice to know.
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/#findComment-12176857
Total: $988.60
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/#findComment-12185635
I have the monitors picked out already (Viotek GN24CB curved) andthe mouse, I dont have a key board picked or anything like that I am open to options, I am in the USA and $1500 or less. Some key things I have been doing research on and have decided on are watercooled and at least a ryzen 5 processor as I am more AMD then Intel. Can add more income down the road but that's for the start.
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/#findComment-12185655
Total: $988.60
I like that I didnt think I could get that much bang for the buck honestly I updated also with the monitors I chose
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/#findComment-12185662
if you are near a Microcenter (I know not everyone is) the Ryzen 7 1700x is going for $150 there, which could save you some money to put somewhere else in the build, like maybe stepping up to an X470 board or better yet, a better COOLER, 120mm AIO's are useless on CPU's and should not exist, for the money you'll get better performance from an air cooler that is just as quiet, if doing an AIO do a 240mm AIO.
https://linustechtips.com/topic/1019634-whaaaat-is-going-on/#findComment-12186303
