Would this MOBO be able to use 2x 270X?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128657
How much money (disregarding power cost and @ the price of litecoins now) would I make in a month hashing with a 270x?
2 270Xs?
3?
Ignore the first 3 answers, I changed the questions.
https://linustechtips.com/topic/101958-will-it-work/
No and no.
A decent 650w would do.
https://linustechtips.com/topic/101958-will-it-work/#findComment-1363675
Any motherboard will work, but isn't too great. Very few pci slots, and it's an intel board. Refer to this site for planning builds. http://www.cryptobadger.com/2013/04/build-a-litecoin-mining-rig-hardware/
You will need to use 1X to 16X risers to plug the gpu's in as there is only one native 16x slot.
To find out potential mining capabilities, use a calculator such as this one. http://bitcoinwisdom.com/litecoin/calculator Don't forget to add in the difficulty increment you want to base your calculations on. You can find a list of previous difficulty increases/decreases, along with analysis of current network here http://bitcoinwisdom.com/litecoin/difficulty
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/101958-will-it-work/#findComment-1364187
