Hello so my specs are
  • CPU
    Intel i5 6500
  • Motherboard
    Asus z170-a
  • RAM
    G.skill Ripjaws v x1 8gb Patriot Viper x1 4gb I know I shouldn’t mix ram that’s not the same but it works
  • GPU
    Asus dual of gtx 1070
  • Case
    Corsair 300r windowed pannel
  • Storage
    3 hdd 1 ssd for os
  • PSU
    CORSAIR CX-M series CX600M 600W 80 PLUS BRONZE Active PFC ATX12V & EPS12V Modular Power Supply
  • Display(s)
    MSI Full HD FreeSync Gaming Monitor 24" Curved Non-Glare 1ms LED Wide Screen 1920 x 1080 144Hz Refresh Rate (Optix MAG24C)
  • Cooling
    Hyper 212 evo with 2 fans and 6 other fans including psu fan
    I mainly use this as a gaming pc with YouTube and Netflix I just wanted to know would my cpu bottleneck my gtx 1070 or would my cpu bottle neck my monitor thanks
https://linustechtips.com/topic/1019508-help-would-it-bottleneck/
depends greatly on the game...but overall yes your CPU will hold you back from achieving anywhere near 144fps in many modern titles...and in some more demanding open world or online games i doubt you'll be able to max out your GPU...You should look for an i7-7700 or something...that way you get a much more capable CPU without swapping motherboard...then sell your core i5 to get some money back.
BIOS update on your board is likely required before you can get rid of the core i5 and use the core i7.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
You will be fine in most modern titles, (just don't go playing Crysis) this was the kind of CPU that the 1070 was originally released for. (Remember folk the 10 series hit when the 6700k was all the rage) The 6500 is only ~9% slower than an 7700, which is a CPU ably capable of powering the mighty 1080 ti (and also the newer 2080 ti) in modern games as most of these modern games are only designed to take advantage of 4 cores and they have taken into account the rather slow development of the CPU over the last decade so most modern games are optimized to take advantage of powerful GPUs that Nvidia has continued to produce in the meantime. Or to put simply in most games you will be fine... (I have seen much older and somewhat slower CPUs ably power faster GPUs than this one without bottlenecking).
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
The problem with getting a better cpu for an older motherboard is older intel CPU's don't seem to drop in price much and spending $350 on a 7700K would be a slight improvement.  It would be better to spend more money and get on a new platform with the best CPU you can afford.  A 2700X or a 8700K would be a significant and noticeable upgrade and it would last for 5 - 7 or more years before being bottle necked by the latest GPU's.
ideal is to buy a used CPU localy through facebook ads or craigslist for example...you don't buy an old CPU new.
Also.. When Games Do use more than 4 cores/threads.. You see 90-100% way more often, and lose GPU usage and FRAMERATE as a result.
You'll want a minimum of 8threads going forward...or more.
Problems like this are hugely mitigated by having 8 threads over 4 threads in multi threaded nature of games.
You can play games with higher minimums and smoother Gameplay.
However you manage that.. As cheap as possible, isn't that hard if you really are patient and want to spend wisely. Inc spending wisely on more than 4threads...
No matter how powerful these 4threads can be, its a thread limitation for many current games as well.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
