So I installed a custom loop from alphacool a while ago, and I want to make sure that I plugged everything in where It was supposed to go.
First is the pump, I plugged that into system fan and then pcie in my psu
The CPU block has a bit of light on it and I plugged it into CPU fan.
The fans are connected to a thermal take fan hub and they work great (I took them from my old aio)
I am mostly nervous about the pump because I have no idea if it's plugged where it needs to be. If anybody can help me with this that would be soooo amazing.
https://linustechtips.com/topic/1019428-need-some-liquid-cooling-clarification/
what kind of pump and motherboard do you have?
Depends on the issue and specific setup of the BIOS. In my case, there is a header for W_Pump that PWM controls the pump speed. The issue here is that not all cases have a low speed warning if/when the pump dies. I am lucky in the fact that i can set my low speed to a certain RPM and still get a warning. I also had to unlock PWM control on that header manually. something about people burning out AIOs...
The CPU header is fine and will meet your needs.
I think i need some clarification. Did you plug the pump into the CPU header? you said something about the block had a bit of light on it and you plugged that into the CPU fan... That ain't gonna work right.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
