so ive noticed low fps in gtav online.. ive done abit of testing and found that in singleplayer i get normal fps around 100-120
but in online my cpu and gpu usage is usually around 50% and only 50fps
im playing on mostly maxed settings with like grass and stuff turned off DOF is turned OFF
also just a side note.. does the distance look really blurry and foggy? or is that just me
my specs are :
1070 8gb
i7 3770k
16gb
https://linustechtips.com/topic/1018998-50-usage-with-low-fps/
my specs are :
1070 8gb
i7 3770k
16gb
gta online consumes far more cpu resources(handling many players and their actions at the same time) than gta 5. So what I believe is happening here is that the cpu is struggling to keep up with all the player actions. I would probably go and upgrade the cpu sometime
Damn....
https://linustechtips.com/topic/1018998-50-usage-with-low-fps/#findComment-12169964
yea i figured the same but the fact that my cpu in the screenshot is using 67% while only producing 65 fps is weird to me
https://linustechtips.com/topic/1018998-50-usage-with-low-fps/#findComment-12170733
