I've been watching the YouTube channel for Linus tech tips for awhile and learning as much as possible about PC's but I need some recommendations because I have never built a PC before. I'm about to start my second semester of college and I need a PC that can work hard but I also want to be able to play some Skyrim or Witcher 3. Would 750 us dollars be a reasonable budget? I don't have a keyboard, mouse, or monitor either. Any advice or recommendations would be greatly appreciated.
Edited by Yogi53
https://linustechtips.com/topic/1018358-first-build/
If you don't have anything and $750 is for everything, I'd look for a 2nd hand tower for like $600 and use the rest for peripherals.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1018358-first-build/#findComment-12163903
3 hours ago, Yogi53 said:
I've been watching the YouTube channel for Linus tech tips for awhile and learning as much as possible about PC's but I need some recommendations because I have never built a PC before. I'm about to start my second semester of college and I need a PC that can work hard but I also want to be able to play some Skyrim or Witcher 3. Would 750 be a reasonable budget? I don't have a keyboard, mouse, or monitor either. Any advice or recommendations would be greatly appreciated.
If you need a monitor and all peripherals and you can only spend $750, this is what you're looking atm. If you can't squeeze another 30 bucks get an RX 570 instead.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1018358-first-build/#findComment-12163915
Uh, no. Just have to go cheap.
https://linustechtips.com/topic/1018358-first-build/#findComment-12163916
you still got some things to learn my friend... brb, I'll make my own
https://linustechtips.com/topic/1018358-first-build/#findComment-12163917
I'm not that smart. Just trying to help, lol.
https://linustechtips.com/topic/1018358-first-build/#findComment-12163920
you didn't do THAT bad... it's just included some changes I really wouldn't take, that psu for example...
this will be my take
https://linustechtips.com/topic/1018358-first-build/#findComment-12163931
Makes sense.
And OP, if you really don't play AAA games then you can get the 2400G (then you don't need rx 580/570) and save some money (or get better parts so you can upgrade later) which plays games pretty well, honestly. Would handle games like CSGO/Crossout/LoL pretty well. Not really recommended, though. BUT, it does work. Just built a 2200G for step-daughter.
https://linustechtips.com/topic/1018358-first-build/#findComment-12163957
Makes sense.
2400g can't justify the cost for me... I would personally step down to a 2200g, does light gaming pretty well too
second hand (consumer or server) hardware is a option too
https://linustechtips.com/topic/1018358-first-build/#findComment-12163964
The 2400g is literally what the i7 just use to be not even that long ago, maybe with a slightly slower IPC, but with way better graphics. I don't see any issue with it if you don't care about a dedicated GPU. The 2200G I just built and used for a week myself while building mine kind of used to much of the processor for my liking (not sure how to say it, the cpu usage was too high for needs). I like to leave some headroom..
https://linustechtips.com/topic/1018358-first-build/#findComment-12163982
