HELP - home NAS solution
Solved by FloRolf,
I can imagine the MacBook is quite slow compared to what you can get.
I'd suggest you buy a sweet 8core Ryzen for your Blender renders and run Unraid on it for NAS aswell as a render server. You might even be able to just use Linux or Windows on it and use shares on there to access over the network. I'd advice against FreeNAS for example, because that won't allow for the blender renders.
Also, shame on you for not backing up your stuff! ![]()
