click on that "?" (question mark) to put a load on the card so that it will actually need the bandwidth and it will report correctly
https://linustechtips.com/topic/1017547-radeon-r7-250/#findComment-12156864
1 minute ago, BojanM said:
I just did and it just changed to x8 @ x8 2.0
oh I may have misunderstood, you might want to re install the card. If that doesnt work check the pins for damage
https://linustechtips.com/topic/1017547-radeon-r7-250/#findComment-12156880
Just now, Swes said:
Regardless it wont affect the performance if thats all the issue, that GPU will not even come close to being held back by 8 lanes however it would be good to check to see if its not something else.
Tried re installing the card and cleaning the slot and pins?
as i Said i have Gtx 750ti and it works fine at x16 and i dont think anything got damaged
https://linustechtips.com/topic/1017547-radeon-r7-250/#findComment-12156886
