First self build
Go to solution Solved by Jurrunio,
If looks is NOT considered
so many fans to do push pull configuration on the radiator and fill in all the fan slots btw.
To give performance per dollar some care:
that fan's a rear exhaust fan, use the stock case fans on the top.
To look fancy and perform well:
My thought is to mount the air pressure fans in the front of the radiator (behind the air filter of the case), the stock radiator fans behind the radiator for pulling air, and the remaining air balance fans for the top and back. All CM fans so they look the same.
Decided to build a computer my self for the first time wanted to go with something that will last a while
Budget USD $2500
Mainly for gaming and light classwork
Will also be overclocking in the future
(ignore amazon pricing was seeing how fast everything could get to me amazon prices would be appreciated but not a huge concern)
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  ($399.89 @ Amazon)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  ($169.99 @ Amazon)
Motherboard: Asus - ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($238.89 @ Amazon)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory  ($209.99 @ Amazon)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Storage: Western Digital - Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($80.17 @ Amazon)
Video Card: EVGA - GeForce RTX 2080 8 GB XC GAMING Video Card  ($779.99 @ Amazon)
Case: Corsair - 750D Airflow Edition ATX Full Tower Case  ($159.99 @ Amazon)
Power Supply: EVGA - SuperNOVA P2 850 W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($161.73 @ Amazon)
Total: $2328.63
Generated by PCPartPicker 2019-01-04 21:25 EST-0500
https://linustechtips.com/topic/1017240-first-self-build/
how much are you into RGB?
Desktop benching:
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154394
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($134.99 @ Newegg)
Motherboard: Gigabyte - Z390 AORUS ULTRA ATX LGA1151 Motherboard  ($238.62 @ Amazon)
Memory: V-Color - SKYWALKER PRISM RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($114.33 @ Newegg)
Storage: HP - EX900 500 GB M.2-2280 Solid State Drive  ($85.99 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Amazon)
Video Card: Gigabyte - GeForce RTX 2080 8 GB GAMING OC WHITE Video Card  ($749.99 @ Newegg)
Case: Fractal Design - Define S2 Black – TG ATX Mid Tower Case  ($144.61 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ B&H)
Total: $1986.91
Generated by PCPartPicker 2019-01-04 22:02 EST-0500
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154445
Desktop benching:
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154544
Quote
Do you think the first and last build will run cool enough when i OC the i9 because heard that they run pretty hot and how easy is the process to OC on that gigabyte board? I have Been hearing that the bios can be a pain to work with compared to the ASUS ones thats why i chose that one in my original post.
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154678
the 9900k is a cooling limited chip, unless you build custom water loop with bigger radiators and higher liquid flow rate, as well as delidding and sanding off the top of the die you will be hitting the temperature limit before the voltage limit. the ML360R and other similarly performing coolers are as good as it gets without all the mess.
Once you found out where all the settings are, it's not difficult. The mid range VRM on the Asus Z390-E/F is what puts me off, they'll get way too hot when overclocking the 9900k, You can adapt to a bad BIOS but can't solve weak hardware.
Desktop benching:
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154720
How far do you think I would be able to push it if at all with this kind of cooling without thermal throttling being an issue?
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154731
1.3V is definitely fine, 1.35V starts to depend on your ambient temperature. See how far you can go in voltage.
I dont know frequency because that's mostly silicon lottery based. I do not guarantee 5GHz because I've seen people throw tantrums when they get a crap chip
Desktop benching:
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154751
Thanks for the info going to help me a lot going into this build!
https://linustechtips.com/topic/1017240-first-self-build/#findComment-12154761
