M.2 Not showing up
Solved by Radium_Angel,
1 minute ago, Jules A said:I went to BOIS to change the boot order and it does show up. Made the 970 as 1st and the 750 and secondary.
I might have installed windows on the 750 because the windows installer said disk 1,2 or 3 so not sure which is which.
There's at least part of your problem.
If you want Windows on your m.2 drive, then physically unplug all other drives, and install windows only to the m.2 (as it will be the only option)
After windows boots up, you can plug in the other drives (powered down of course) and use as normal.
