well i planned to buy a Rx 580 this year because of my budget and i am about to place the order and then i heard about upcoming gpus form both nividia and amd, now guys what should i do place the order or  wait for a brand new gpu series, waiting is not may concern. all i need is good gpu for gaming and modeling under 300$
Cpu :- Intel core i5 6402P
Mobo :-  gigabyte b150m-ds3h-cf
Ram :- 12 gb DDr4 - 2133 cl 14 288
Gpu:- ASUS ROG Strix Gaming RX 570 OC 4GB
psu :- Corsair VS550 550-Watt
https://linustechtips.com/topic/1017108-help-me/
If you're throwing the AMD GFX card into the system you have listed below your message, then you should be fine. You can play the waiting game forever and something newer/faster/stronger will always be "around the corner"
Only question is, how long as you willing to wait?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1017108-help-me/#findComment-12152859
Just place your order, Nvidia's new GPU will blast your budget to pieces while AMD's new GPU doesnt even have rumours yet. AMD's busy on 3rd gen Ryzen atm so don't expect new GPUs from them at least in the first half of this year.
Desktop benching:
https://linustechtips.com/topic/1017108-help-me/#findComment-12152861
Why spend 300 on an RX 580 when you can get used or cheaper examples of 1070s for the same cost?
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1017108-help-me/#findComment-12152874
Just now, Chad The Greats said:
Maybe Freesync? And maybe those deals aren't available in his region? If they are he should go for a 1070 though. Great card.
He said under 300$ so I'm assuming he's American. 1070's retail for 299$ now and you can grab them for 250$ off of ebay. Hell you can get a fully loaded GTX 1060 for under 300$ and it'll surpass the RX 580. Doesn't Nvidia work best with modeling anyways because of CUDA?
The Louvre
https://linustechtips.com/topic/1017108-help-me/#findComment-12152906
Well i could've gone for a used 1070 but used gpus are quite hard to find where i live. So rx 580 became my choice since many people suggested me to buy rx 580 over 1060
https://linustechtips.com/topic/1017108-help-me/#findComment-12152939
Sorry that i didn't mention where i live. I am from India and here rx 580 8gb is cheaper than 1060 6 gb and used card are nearly impossible to find
https://linustechtips.com/topic/1017108-help-me/#findComment-12152978
How much 3d modeling will you be doing? If it's going to be a fair amount you ought to stick with Nvidia cards because of their proprietary CUDA technology.
The Louvre
https://linustechtips.com/topic/1017108-help-me/#findComment-12153002
I am planning to upgrade my ram along with gpu and maybe i can wait for a one or two months but no more than that
https://linustechtips.com/topic/1017108-help-me/#findComment-12153004
Mainly i need a gpu form decent gaming and some basic modelling, modelling for me is just a hobby not more than that
https://linustechtips.com/topic/1017108-help-me/#findComment-12153015
Ah well then you're probably stuck with the RX 580 as your best option
The Louvre
https://linustechtips.com/topic/1017108-help-me/#findComment-12153025
Tanx for the replies guys.one more thing, i know i am asking too much for my budget but is rx 580 viable in 2019 can it play upcoming titles atleast in medium settings??
https://linustechtips.com/topic/1017108-help-me/#findComment-12153095
Yeah it's close to 1060 performance.
The Louvre
https://linustechtips.com/topic/1017108-help-me/#findComment-12153105
