Hey! Back for more advice.
I am a Premiere and Avid editor and more recently I've been running into longer and longer render times as well as instability. I'm currently using a 2016 Dell XPS 9550 for the bulk of my edit work so you can see my issue.
Because of this I've been looking into building a hyper optimized PC which I can use solely to render HD and UHD video for about $1200 US.
Any suggestions or advice is greatly appreciated!
https://linustechtips.com/topic/1016676-purpose-built-render-machine/
For this I'd definitely go for a Ryzen CPU
Something like that should work. Even without the mail-in rebate it's just under your budget.
For premiere there is a extention www.voukoder.org That allows you to gpu exporting on nvidia and amd gpus for much faster exporting, and let you use x264 and x265 which are better encoders that what is included in premiere(so better quality for same time, or faster for same quality)
