Hello, my name is Aleksanander Stojnsek, and i'm from Slovenia (that’s why my english is not perfect). In december 2018 i bought my new cpu i7 8086K, i pick this cpu instead of cheaper i7 8700K, because i want to avoid silicon lottery, and get the cpu that can hit 5ghz on al cores, with lower voltage. Few days ago, i finally decide to overclock my new cpu, and see what is capable, the final result was huge disapontmant. I saw some i7 8086K hitting 5.1 Ghz with 1.3 voltage, and even the vorst samples can hit 5 Ghz with 1.3 voltage, but my sample its not stable at this voltage, i try 1.33 voltage (because of high temperatures, i didn’t go higher) for 5 Ghz and  it’s still not stable. I pay 500 € for cpu that can’t hit 5 Ghz with resonable voltage, i could get i7 8700K for 100 € less and I would probaly see better results. Some i7 8086K can hit 5 Ghz with 1.2 Volts but mine can’t even hit 5Ghz with 1.33 Volts (I need 1.3 Volts to get 4.9 Ghz stable, so I will probaly need at least 1.35 Volts to get 5 Ghz stable, that’s just to much for a i7 8086K), i think I get defective sample (average 8700K that was not even binned properly). I realy don’t know what should I do.
Edit: Im using ROG STRIX Z370-G GAMING (WI-FI AC) with updated bios.
https://linustechtips.com/topic/1016672-i7-8086k-overclocking-issues/
Gonna be completely honest, it's a bit of a gimmick. Overclocking is never guaranteed, there's always silicon lottery. However, have you tried load line calibration yet?
Primary PC:
PSU tier list
How many watts do I need?
Yeah getting an 8086k doesn't mean you will get a great overclocking chip but rather one that can reach the required base and boost clocks if the 8086k. I always thought it was weird that people would assume this. Anyways you could have just turned MCE if you wanted 5ghz on all cores. The temps issues seems like you just don't have enough cooling to overclock properly.
Yeah that 5GHz advertised by Intel is just the single core turbo, other parameters are the same as 8700k. You really should have asked here before buying the 8086k.
Desktop benching:
How can be my sample so much worse?
https://www.gamersnexus.net/guides/3343-binning-a-cpu-volt-frequency-intel-i7-8086k
Speed/Model
Core i7-8086K
Core i7-8700K
4.6GHz
1.2V/73°C
1.2V/74°C
4.8GHz
1.2V/ 77°C
1.225V/80°C
5.0GHz
1.275V/87°C
1.325V/98°C
5.1GHz
1.325V/98°C
Overheat
3 minutes ago, svenhassel said:
8086 should hit 5ghz with 1.3 volts (some samples hit 5.1 with that voltage).
For colling im using Intel Thermal Solution TS13X (BXTS13X), im waiting for evga clc 280
*should* being the key word.
I cant overclock my FX 8350 for ****.  Most people can get it to 4.6 - 4.8 OC, with some getting 5.0ghz.  Me?  4.4ghz and it cant even stress test without locking up PC.  I gave up because it just...wouldn't...take an overclock well.
Speed/Model
Core i7-8086K
Core i7-8700K
4.6GHz
1.2V/73°C
1.2V/74°C
4.8GHz
1.2V/ 77°C
1.225V/80°C
5.0GHz
1.275V/87°C
1.325V/98°C
5.1GHz
1.325V/98°C
Overheat
Worse?  Does it run at the advertised speeds it was sold to you as?  Than its working as intended.  You cant guarantee an overclock, like everyone else said.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I am going to be completely honest as a fellow owner of the 8086K and an 8700K they overclock about the same.  My 8086K can boot and run games at 5.2 @ 1.36 vcore with no offset and my 8700K can boot and run games at 5.1 with about that vcore too.  They are the same processor essentially also, double check that you have turned off Multi Core Enhancement.
Silicon Lottery actually told me after delidding my CPU that I would require 1.412 vcore to get 5.1 on the 8700K and 1.410 vcore to get 5.1 on the 8086K both stress test stable.  So essentially the same thing.
BLACK and BLUE Build
i9-9900K - 5.2 Ghz @ 1.305 vCore, 32 GB Corsair Vengeance RGB Pro (@ 3200 Mhz), Gigabyte Aorus Z390 Extreme, EVGA RTX 2080Ti XC Ultra, Samsung 970 Pro, Samsung 970 EVO, Dual Custom Loop Cooling, Thermaltake Tower 900, AX1500i
VR Build
i7-8700K - 5.1 Ghz @ 1.36 vCore, 32 GB G.Skill TridentZ RGB (@ 3200 Mhz), Asus Maximus X Hero (Wi Fi ac), 2x EVGA GTX 1080Ti SC Black Edition, Toshiba NVME, Custom Loop Cooling, Thermaltake Core P5, HX1000i
FreeNAS Server Build
Pentium G5400, 8 GB Kingston HyperX Fury (@ 2400 MHz), Asrock H370M-ITX/ac, Intel 320 System SSD, 4x Hitachi 7200K 4 TB HDD, Thermaltake TR2 650W, Cooler Master Master Liquid Lite 120, Bit Fenix Prodigy
Daughter's First BuildCore i3-6100, 16 GB Corsair Vengeance LPX (@ 2133 MHz), Asrock H270M-ITX/ac, XFX RX-580 GTS, Custom Watercooling (Both CPU and GPU) 2x Corsair Force LS, PowerSpec 550w, NZXT H200i
@svenhassel Since not all processors are the same, that guide you used may need to be tweaked a bit in order to make it work for you.  Intel datasheet says that 1.52 vCore is the maximum that the CPU can handle.
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/8th-gen-core-family-datasheet-vol-1.pdf
Page 123 if you are looking for it.
I am wondering why you are so concerned with going above the 1.30 vCore.  If your cooling solution keeps the CPU below Tj Max by a decent amount then why are you specifically worried about it.  When I benchmark using my PC I push my overclock up to 5.35 Ghz @ 1.49 vCore and the temps never go above 89° C.  Yes I know that the higher voltage COULD potentially decrease the lifespan of my processor, however I am not using that for a 24/7 overclock.  Silicon Lottery even shows that on their Delidded CPUs you needed to use between 1.4-1.425 vCore.  I got a bad chip too, but I was getting 5.1 Ghz non-delidded @ 1.36 vCore and it was getting to that same 89° C.
I have not watched the guide you used, however things to make sure, Multi-Core Enhancement is off, Short and Long Duration Power Settings are at 4095.
VR Build
  • 1 year later...
Hello I finally managed to pass an OCCT without error
1 hour test, large files, avx 2
8086k processor
Aorus Master Z390
vcore 1.33
Turbo LLC
Are these results ok? For some people it seems they are average and for other I spoke about it they are very bad for this chip
8086k Aorus Master Z390
disabled c state and speed shift
I would like to set up an adaptive profile but not so sure how to do..
Also should I leave c state and speed shift enabled?
Thanks
For the full settings :
MANUAL PROFILE
ADVANCED FREQUENCY SETTINGS
CPU Base clock 100
CPU upgrade : auto
Enhanced multi core performance : disabled
CPUclock ratio 50
FCLK frequency for early power on : 1Ghz
XMP : profile 1
Vt-d disabled
Advanced cpu core settings
AVX offset : 0
Uncore ratio : auto
Intel turbo boost technology : on
Cores : 50 all cores
C state : disables
SpeedShift : disabled
ADVANCED VOLTAGE SETTINGS
Advanced power settings
CPU internal AC/ DC Load Lines : auto
CPU VCORELoadline calibration turbo
CPU vcore current protection : auto
Manual
CPU vcore : 1.325
VCCIO 1.15
CPU SA : 1.15
CPU current limit 255
All other power limit maxed
so speaking from experience
while it sucks you can't get 5ghz
4.9ghz is imperceptible from 5ghz in actual use
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
