144hz monitor only goes up to 120 fps?
Eggarro
Hello. I recently built my new gaming pc, and set up my monitor and everything. All was going quite well until I realized that, after turning on my fps counter on the monitor, it only went up to 120 frames per second. I tested this on a few games, and no matter the graphics quality, the fps never went above 120, on both in game counters and monitor ones. I used a cap of 144 fps in the games, and then no cap. I got the exact same result. In the monitor settings, I can only go up to 120hz!
Help!
What monitor, what cable?
Primary PC:
The problem is probably  the HDMI cable. I would suggest getting a Displayport one, because HDMI doesn't support higher than 120, at least on the older versions. Monitor is fine.
2 minutes ago, handymanshandle said:
What GPU do you own?
Aorus geforce gtx 1060 6gb, don't think this matters, but, there's three fans in it, and it is rgb
2 minutes ago, hiitswilliam said:
Yeah. The cable or monitor can often cap off the frame rate.
So... what can I do about it?
Certain monitors are limited to 120 Hz over HDMI, others aren't (with the same version). It's a limitation of certain monitors, not a limitation of the HDMI standard.
But my monitor is 144hz, so wouldn't the issue be the cable?
Your monitor only supports 144 Hz over DisplayPort. It is limited to 120 Hz over HDMI.
This restriction is not imposed by the HDMI standard, it is specific to your monitor.
2 minutes ago, Glenwing said:
You need to use DisplayPort.
Sorry, kind of new to all of this cable stuff. Does that mean I just use a different port, or do I also need a different cable?
Here is a cable: https://www.amazon.com/Cable-Matters-DisplayPort-Feet-Resolution/dp/B005H3Q59U
You need a new cable, the HDMI one won't support 144 hz. It plugs into a different port than the HDMI, but you should be able to find that port just fine on both the GPU and monitor.
Different cable and different port. The monitor should have come with a DP cable included.
Im 12 mentally every time I come across a thread that mentions this cable...I snicker.  Cant help it.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
why?
Ok. Thanks guys! Really appreciated the help.
4 minutes ago, hiitswilliam said:
why?
If you don't know why, you aren't 12 yet ;).  I don't want to ruin it for you lol
  • 4 weeks later...
Why?
3 hours ago, Eggarro said:
Why?
DP = Double Penetration in ye ol' pr0n search engine
@Eggarro
Just an aside, might want to do a frame skip test on blurbusters for the VG278Q, I have the same monitor and it's smoother at 120hz anyways.
144hz
120hz
  • 3 weeks later...
On 1/27/2019 at 2:05 AM, CorruptedSanity said:
@Eggarro
144hz
  Reveal hidden contents
120hz
Ok. Thanks! Does the site explain how everything works, since the pictures look kind of confusing
Look at the trails. Shorter the better; your monitor pixel refreSH RATE can’t keep up to the 144hz. Thus the trails. Or ghosting.
Yes, there are some instructions at the top of the page.
The trails are because of the exposure of the camera, an exposure of 1/10 of a second at 120hz equals 12 frames being refreshed while the shutter is open.  If I had set it to 1/6 exposure you'd see 20 boxes lit (120\6).
If you do this test and have a broken trail (like the 144hz photo I posted) that means the monitor basically can't refresh fast enough and "skips," frames. It is very apparent now that I've switched between 144-120hz on my monitor.
EDIT
Just tried the test again at 144hz, turning g-sync compatible turned on and after a restart.  It didn't frameskip anymore!  1/10th exposure, 14.4 boxes lit.
144hz w/ G-Sync Compatible turned on
He has to make sure vsync is set to OFF, also set to OFF in game.  Or don't use the FAST option in vsync.. just turn vysnc on.  Your refresh has has nothing to do with what happens with frame rates.  Turn vsync off like I said and see if you can get passed 120fps and into high AAA famre rates.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
