So I have an nonmodular psu what’s the best way to cablemanage all those extra cables I have that I’m not using I do have a fairly big space in the top area of the case right above my other hdd and that where all the cords are now but I would like something Alitalia but more secure and permanent that won’t just fall out after a while thanks in advance
https://linustechtips.com/topic/1016378-cable-management-for-extra-psu-cables/
Rubber bands and paper clips work pretty well in my experience.
If you can rubber band all the cables together, and then use a paperclip to attach them to the case via a drive mounting point or something like that, it makes for a crude but very effective way to cable manage them.
Well thanks this will help quite a bit
