I have an Intel I7 2600 chip, gtx 960 2 gb, 16 gb of ram, and an 850-watt power supply. My question is, is overclocking even an option for me? It isn't necessary, but if I could do it, that would be great. I am only using air cooling using a pretty basic be quiet CPU cooler.
https://linustechtips.com/topic/1016196-overclocking-help/
400MHz OC + 5% by BCLK adjustments if you have a Z68/Z77 board, but if you dont have one, it's not worth buying a board for it.
Desktop benching:
https://linustechtips.com/topic/1016196-overclocking-help/#findComment-12144460
Yep, your GPU can be overclocked. Here's a short GPU overclocking guide:
- Download MSI Afterburner and Unigine Valley Benchmark
- So you increase the core clock by a bit at a time (maybe 25MHz at a time) and same goes for memory.
- Then you stress test your GPU (run Unigine Valley Benchmark) for some time.
- If the application doesn't crash, then your overclock is stable but if Unigine Valley Benchmark crashes, then your overclock isn't stable.
- If your app crashes, you have two options: either add more voltage or decrease the core/memory clock.
Your CPU can be BCLK overclocked (with an appropriate motherboard), although I don't recommend it since it's hard to find something stable that actually gives you a decent performance bump.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1016196-overclocking-help/#findComment-12144477
Thanks. I have afterburner, but ill look into getting Unigine Valley. Thanks.
https://linustechtips.com/topic/1016196-overclocking-help/#findComment-12144488
