So on my new build, which is very good overall, except for one thing, the Cable Management, there is almost none at all, since the case dosent seem to have space for it (almost no space on other side of case).. Any tips on what I could do here? I attached some pictures of it.
The case: https://www.newegg.com/Product/Product.aspx?Item=N82E16811147122
https://linustechtips.com/topic/1015661-cable-management/
You could just move that HDD down a slot or two and, just tuck the excess cables above it. That's how I usually did it.
All the other cables can just be grouped together with some zip ties or better yet, twist ties.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/1015661-cable-management/#findComment-12140224
