First time building a PC, did I apply paste right?
Solved by Swarlos,
Those are good temperatures. Idle temperature doesn't mean much of anything as long as your load temperatures are good and low, and 53c under load is quite low. If you want to bring idle temperature down you can set the fan curve on your CPU to run faster at lower temperatures. I think your CPU fan is just running really slow at idle because it doesn't need to go any higher.
Featured Topics
Cramig88 ·
Posted in New Builds and Planning3 -
Ghostsanonymous ·
Posted in Displays3 -
1
halfbood_drag0n ·
Posted in New Builds and Planning1 -
7
1
19
13
1
