May sound a bit of a silly question but i haven't seen a confirmed statement on this.
So i have a DDC pump im not sure if its one from swiftech or lilang etc.
Im looking at some Reservoirs maybe something like the Heatkiller DDC tube or the EK tube for DDC pump's.
Are all DDC pumps the same after the tops removed? will any DDC Pump work with these reservoirs regardless of branding?
Asrock X670E Steel Legend - AMD 7600X(5.5Ghz) -  XFX Speedster-Zero EKWB Edition 6900XTXH
-32GB Kingston Fury Beast 6000mhz DDR5 - WB Black 1 & 2 TB NVME -EVGA 1300W G2
Full loop 2x480mm XSPC RX Rads / Thermaltake Pacific W8 Block
https://linustechtips.com/topic/1014612-ddc-pump-applications/
-= Moved to Liquid Cooling =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1014612-ddc-pump-applications/#findComment-12132294
Any variant of the DDC will work as they are all the same dimensionally but the versions can vary in wattage providing better performance.
If you can fit a heatsink on the DDC is commonly recommended as the pump is not actively cooled and can get quite warm.
https://linustechtips.com/topic/1014612-ddc-pump-applications/#findComment-12132595
