What CPU you got? Wouldn't want a bottleneck.
Primary PC:
PSU tier list
How many watts do I need?
1080 Ti if you can save a good amount of money if not then just go 2080 already, they perform about the same but the 2080 has the new "promises" that might eventually... someday... be a thing.
As stated above these GPUs are A LOT faster than a GTX 970 so careful with your CPU not becoming a bottleneck.
Personal Desktop":
Luna, the temporary Desktop:
I would look into GPU prices of 1080ti and 2080, if they're similar, get 2080, if you can get 1080ti for cheaper than 2080, get 1080ti instead.
And to add to a pile, check CPU for possible bottlenecks.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
My CPU is a intel i7-9700k
