i7-6950x Overclocking Questions
Solved by Fasauceome,
7 minutes ago, Atra1n2 said:mid to high 70s
Good temps.
I keep my firend's 5960X under 70 but that's because he refuses to dust off his radiator so it always leads to excessive temps down the road. My only advice now is to get the voltage as low as possible. The aforementioned 8 core runs 4.1 all core and 4.3 6 core, with 1.15 volts, so I bet you can do even better.
Featured Topics
rickymohk ·
Posted in General Discussion1 -
Rbakker02 ·
BaidDSB ·
Posted in General Discussion5 -
1
Mistr J ·
Posted in Troubleshooting3 -
2
4
2
coolbean28 ·
Posted in Graphics Cards8
