Hellos,
     Searching for a ARGB AIO pump for my new Corsair 570X mirrored glass (one with Type C) case. This is the 2nd best looking AIO pump I can find!
Can I control the ARGB on a motherboard that does not have RGB headers? I own the ASUS ROG Maximus Hero VII Z97 board.
My new case has the corsair hub and node for the extra SP120 or LL120 fans I will be buying. I believe I need to pick up a Corsair Commander Pro as well, which is fine.
Can I control the AIO pump lighting with Corsair ICue software or connect it to the 2 types of hubbs?
https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE7W67082&Description=DEEPCOOL CASTLE&cm_re=DEEPCOOL_CASTLE-_-13C-002K-000A8-_-Product
I am not a fan of company logos on the pump. Therefore my options are slim... D'oh!
Thanks in advance!
https://linustechtips.com/topic/1014436-deepcool-castle-aio-question/
18 minutes ago, mxk. said:
Corsair stuff only controls Corsair stuff, so you can't control it with iCUE.
OK thank you. Is there a way to sync this pump without Aura? Can I download aura and use with a Z97 board?
yes. Sorry for the late response.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
