Are my temps safe ?
Go to solution Solved by Wufflez,
Temps are good, ye. PSU has no effect on temps. More fans, more aggressive fan curves, and an airy case will cool down your temperatures. Don't start worrying about temps unless they're in the high 90s
3 minutes ago, Lowspecgamer said:
Now max temp went to 80c but it’s no consistent
80c is still a good temp. I'd say around 90c is bad, but it should throttle back at a certain temperature (most likely in the range of 90-100c) to prevent damage to the GPU.
https://linustechtips.com/topic/1014123-are-my-temps-safe/#findComment-12128542
