So
I just bought a racing kinda chair. It was like 350$.
Im taken all the parts out, and with the 5 wheels it came with 3 are spinnable like with your hand.. and then 2 are very hard to spin.... it’s almost like there is no space in the “shaft”
I really don’t want to re pack it’s all up to bring it back... is this normal?
In the photo the left side you can see the metal bar they are attached to but the right one there is no space...image.thumb.jpg.29b7c0b3fe5e24f2be453235d8ac7a95.jpg
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/1013048-chair-wheel-help/
3 minutes ago, BOBWARPATH said:
That's normal. They are cheap wheels. I ended up buying some bearing wheels from home depot to replace mine
How do you know they are going to fit?
theses ones you kinda just push them hard in.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/1013048-chair-wheel-help/#findComment-12120429
