AutoCad Help
Go to solution Solved by Jotoco,
You might think you need a good graphics card for 2D AutoCAD, you don't. Source: Me, I am an Engineer and use this program all the time.
You will me better served by a good CPU, SSD and a good amount of RAM. Even if you have only integrated graphics.
VERY few Engineering programs use the GPU. Mostly for 3D rendering. If you're a Architecture student that does a lot of 3D rendering, or a mechanical student that constantly works with 3D design, it might make sense to pay a little extra for a dedicated GPU.
But for 2D Cad and most other Engineering programs, you don't need it.
I am a Electrical Engineer for reference.
To be honest, my Surface pro 4, i5 4GB RAM was fine for 2D AutoCad, you wouldn't notice any slowdown with 1 project and an Excel spreadsheet open at a time. Which is not something you will always do after sometime. As you progress you will probably be working with multiple projects, spreadsheets and possibly other software open, that is when RAM comes in.
Grab a good i5 or 7 (can be U series, no problem, 8th gen if possible), a nice fast SSD and 16GB of RAM and you will be set.
Graphics card is just icing on the cake. Icing that will kill your battery life if you opt for it.
I was looking at this laptop for college use. My use case is Programming, 2D CAD, computer modelling and simulation. Will this one serve me good? It has a core i7 8550u, 8gb ram and a 1tb hdd. I will dump a 250gb ssd in it. And it also has a AMD Radeon 540 4GB GDDR5 Graphics for the cost of 1028 US Dollars? So please help me out hereimage.png.4efc25bfa3b9e6e2470b2671582d8ab7.png
https://linustechtips.com/topic/1012827-autocad-help/
9 minutes ago, Roschlynn Dsouza said:
Do you 100% need a laptop? Do you only need it for AutoCAD?
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12118878
That isn't too great for 1K USD, mind you it will likely cost more due to your country. I would still try to find something with a 8750H and a 1050TI, but that might not be possible in your country.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12118879
This will be for use in college as i already have a AMD Ryzen 5 1500X and a GTX 1050TI based desktop to handle it. I need a laptop for presenting my CAD Designs to teachers when im in college
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12119324
Yes its too much this was the only one i could find the lenovo one i mentioned
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12119329
What's your budget in INR? Any preference on weight and battery life?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12119930
If you always have wifi you can just remote desktop into your desktop PC and get it's full speed without much latency.
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12120828
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12121636
5 hours ago, Roschlynn Dsouza said:
75000. Any weight and battery life will do
Can bump up budget to 80000?
Desktop specs:
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12122348
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12122736
  • 2 weeks later...
the lenovo one i mentioned is a core i7 8550u. ram ssd are upgradable so will definitely go for a 16gb upgrade.
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12159813
On 1/7/2019 at 12:33 AM, Roschlynn Dsouza said:
im ready for it
Lenovo Y7000 with i7-8750H (from Newegg India, price including VAT)
Desktop specs:
https://linustechtips.com/topic/1012827-autocad-help/#findComment-12166176
