Hello all, I need help with a build. My budget is no more that 300 bucks. The things I am going to be using it for is old games and ps1, nes, SNES emulation. The old games I am going to be playing are Diablo 2 LOD, Warcraft 3, Star Wars The Old Republic, Star Trek Online, Path of Exile, Titan Quest, and Warframe. I would like to play these game at no minimum of Medium Settings. I have a Xbox one X so that's what I play my AAA titles on. Can this be done? Any help would be much appreciated. Thank you all.
https://linustechtips.com/topic/1012007-need-help-with-build/
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($93.99 @ Amazon)
Motherboard: ASRock - A320M-HDV Micro ATX AM4 Motherboard  ($53.98 @ Newegg)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($53.99 @ Newegg)
Storage: Kingston - A400 120 GB 2.5" Solid State Drive  ($23.99 @ Amazon)
Case: Corsair - Carbide Series 88R MicroATX Mid Tower Case  ($49.99 @ Corsair)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $305.93
Generated by PCPartPicker 2018-12-24 06:28 EST-0500
Something like this? I don't know if this is sufficient enough, but Vega 8 is enough to run some newish games, so it should be fine.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1012007-need-help-with-build/#findComment-12112891
