headphones + mic issues
I tried looking it up, nothing worked. I have headphones with a microphone connected, and I cannot get them to work at the same time. I have to either use the mic or just have headphones, will not work at the same time. IDK what is going on so that is why it is a bad description.
https://linustechtips.com/topic/1011907-headphones-mic-issues/
which headphones?
4 conductor 3.5 mm?(3 black rings around it)?
https://linustechtips.com/topic/1011907-headphones-mic-issues/#findComment-12112107
51 minutes ago, Fosh612 said:
After a nap I figured it out... odd.. but thx for trying to help me. It is a 3.5mm jack, but I have a USB connector
naps are good
remember we use to fight them when we were young dumb and full of
anyways glad you figured it out
https://linustechtips.com/topic/1011907-headphones-mic-issues/#findComment-12112415
