My DLSR triggering wireless flash?
Solved by scottyseng,
1 minute ago, slickboss21 said:I'm curious, how does this actually work? Do all cameras send out a signal every time they take a photo? WHat's this feature called? What form does this signal take? Just RF?
There are two main trigger methods that I'm aware of, optical and radio frequency (RF). My guess is that his flashes were set to optical trigger and your flash was setting them off (They go off when they sense a flash). If the flahses were radio frequency triggered, you'd have to have a wireless trigger (Or a flash with RF support) to set them off (Even then, they would have to be paired with the master flash first).
