11 hours ago, _Hustler_One_ said:
If you have space to place it inside your case, then go for it.
For me because this simple hub I mentioned to you is only $3 in my local computer store and it's small enough for my ITX case then I can't see other hubs are more suitable for my system.
Space? ? you can't even imagine how much space I have in that case I can fit 10 of these easily, well Thank you so much for the help I think I will go with the silverstone and connect it directly to the SATA 12V, not sure about the mobo.
https://linustechtips.com/topic/1011576-case-fans-help/page/2/#findComment-12130747
