Hello everyone,
I need some serious help. I bought some parts online to build an workstation/server for me and some friends so we don't have to buy a server in a server center.
The workstation/server contains:
2x Xeon 5670
32 GB DDR3 Registered ECC
Mainboard Fujitsu D2618-C14 GS 3
GPU GTX 560
750w Power supply
So the problem is that it won't post. I'm not getting a screen at all and the fans are spinning at 100% and I'm not getting a screen at all I double checked all wires and replaced the bios battery and resetted the bios.
If any of you have any idea how to fix this or has tips on how to solve this please help me out
Mainboa
https://linustechtips.com/topic/1011334-workstationserver-not-posting-pls-help/
start by taking out all but one stick of RAM and one of the CPUs. if that dosnt work, go through all the RAM sticks and if still nothing try swapping the CPU for the other one. if you still have no POST id guess the motherboard or CPUs are dead
Builds:
Ok thank you I'll try it out when I'm home. But there is one more question I have can it be that the graphics card isn't compatible with the MB?
if it has a PCIe slot and you didnt mangle it down into something else the graphics card is compatible.
Builds:
So I swiped everything and still no response. I swiped out the graduation card to an r7 240 and this one doesn't need a power cable and the fans are not turning in any direction. But when I hold the power button for like 4 sek the PC dose shut down. So is it save to say that the graphics card isn't supported or anything like that and the board works?
im not quite sure i understand tbh, you swapped out the graphics card and then did it work??
Builds:
Nah sadly no the fans of the card weren't spinning and I didn't get an video output.I have a therory thoe, I think the board is alright since I can just turn it on and all fans are spinning and I can power it off by pressing the on/off button for 4 seconds and I don't have to pull the plug. So I think the motherboard bios don't know this CPU('s) so I just bought an cheap X5500 for 5€ or so and hopefully the board will boot with that CPU, and when it dose I'll try to update the bios to the latest version and just hope that it'll boot with the dual X5670 CPUs. Whish me luck my friend I'll keep you updated if you want to.
