at what resolution and doing what?
Builds:
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107564
Yes, the 1226 will bottleneck a 1070 in AAA titles.
The 1230 and 1240s will be less likely to bottleneck, but you still may experience some due to its lower clock speeds compared to traditional desktop i7 chips that have higher clock speeds.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107565
hmmmmmmm, then what should i upgrade
i have a
i3 4150
ga h81m ds2
2x8gb ddr3 1600mhz
gtx750ti
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107594
13 minutes ago, N0ne0324 said:
i gonna run it at 1080p 144hz
yah likely wont be doing that, grab an I7 4770/4790/4770k/4790K instead
Builds:
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107613
but i7 kinda expensive, e3 1230 v3 cost 780rmb(112usd),e3 1240v3 cost 800rmb(115usd),and i7 4770 cost 1080rmb(156usd) and i74790 cost 1100rmb(159usd)
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107665
ah yah you could get one of the Xeons i guess, the hyper threaded ones arent a bad pick
Builds:
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12107667
emmm I have another question, the motherboard's pcie x16 slot is only support pcie2.0,will the gtx1070 got performance loss??
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12110484
No a 1070 will not eat up enough bandwidth , even the Titan V doesn’t fully consume a pcie 3.0 slot so a 1070 will do fine on 2.0
theres a pretty good web app that looks for “bottle necks” https://thebottlenecker.com/calculator
Single core cinebench can be a useful tool for getting a feel for how the CPU will do gaming wise
https://www.cpu-monkey.com/en/cpu_benchmark-cinebench_r15_single_core-7
If you can get game bench marks for CPU X and CPU Y is about 10% slower in Cinbench it’s going to be around 10% slower in games as long as you compare similar thread counts . It’s not the end all tool but it’s good enough for rough decision making.
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12110648
no thats fine
Builds:
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12110700
8 hours ago, Bananasplit_00 said:
no thats fine
okay,thx guys
https://linustechtips.com/topic/1011332-will-it-bottleneck/#findComment-12112039
