you're no caveman, you just have a stuck caps lock.
Is that a 2.5" SSD or M.2 SSD?
Desktop benching:
https://linustechtips.com/topic/1011232-help-im-a-caveman/#findComment-12106917
Just now, NUKE64 said:
SATA III
Answering your own questions, impressive
A quick Google search yields this convenient video
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1011232-help-im-a-caveman/#findComment-12106922
4 minutes ago, NUKE64 said:
also side note!!!!! i have a msi gtx 750 and the gpu is way too big! the cooler wont fit!!! what extender cable do i need for that also?!?!?!
1. Your PC must be pretty small to have a GTX 750 be way too big.
2. What do you mean 'extender cable'? If the card doesn't fit it doesn't fit. Please, don't try one of those extending cable things to put the GPU outside of the case. It's an honestly horrible solution.
https://linustechtips.com/topic/1011232-help-im-a-caveman/#findComment-12106932
21 minutes ago, NUKE64 said:
case does not matter (cardboard box)!!!!! and also it fits....just that the gpu blocks the cpu cooler
replace the CPU cooler with one that doesnt block PCIe slots then, or put the graphics card in the second x16 slot if the board has one
Desktop benching:
https://linustechtips.com/topic/1011232-help-im-a-caveman/#findComment-12106973
58 minutes ago, NUKE64 said:
i just want to know if i need a PCIe or just a PCI
What does this mean? Also, remember to use the quote button for replying to people. Also, please Google your problems before asking the forum, I think you'll find many convenient solutions there. Pictures being added to the original post helps too, I am getting a very bad mental picture given what you've described.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1011232-help-im-a-caveman/#findComment-12107047
