USB Thumb Drive Issues
Go to solution Solved by Electronics Wizardy,
If its write protected, its probably a dead usb. Just get a new one. This is probably unrelated to what you were doing.
A while back i wanted to make a windows install usb, and i didnt know how. I figured that if I just throw the boot files from windows on to the usb drive it would work. But now the usb drive has write protect. Ive tried every meathod off of youtube and google, but nothing works... If anyone has a good solution please let me know
https://linustechtips.com/topic/1011077-usb-thumb-drive-issues/
2 hours ago, butters9m said:
this one is 128gb though
In UK you can get Sandusky 128gb USB3 for about £20 ($25)
PC: Ryzen 9 5900x | RTX 3080Ti | Asus Prime B450-PLUS | ASUS ROG Strix 1000W Gold | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD + 2TB NVME + 6TB WD BLACK | Windows 10 Pro + Windows 7 Ultimate
Laptop: MacBook Pro 15" 2018 | i9-8950HK | Radeon Pro 560X | 32gb RAM | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 16.5 with Dopamine 2 + Trollstore 2
https://linustechtips.com/topic/1011077-usb-thumb-drive-issues/#findComment-12105980
