I am planning a pc build and i was checking ssd's and hdd's. i already have a smallish SSD (256GB) so i can get my OS and some games on it. so i checked some prices and found a good ssd vs hdd comparison for price. 8TB WD Gold is $302 and a similarly priced 2TB drive from Samsung(860Evo at $299) is available. i know its a bit of an impossible question because they offer vastly different purposes but what would you say is the better deal? 8TB vs 2TB for the same $300?
ps-chose the unnecessary Gold variant just for higher storage amount and maintaining higher HDD performance
https://linustechtips.com/topic/1010921-which-drive-quantity-vs-speed/
Well, do you actually have something to fill the 8TB with? Hell, do you have something to fill 4TB with, even? Personally, I'd go with the SSD and invest into a separate NAS later on for rarely-used bulk-storage. You can fit a whole lot games and stuff into a 2TB SSD and load-times will be vastly, vastly superior to any spinning rust-drive.
I am a bit of a hoarder when it comes to games and movies and such, in my current PC i have a 256gb SSD (Full) 1 TB WD Black (Full) 1 TB WD Blue (Full) and another Half Full 1TB WD Black. I would definitely enjoy the SSD speeds
If it is just for large sized movie files, documents, photos and such, I'd get a high capacity HDD.
Movies won't play faster, when put on an SSD.
I would put your games onto an SSD, due to the faster load times, etc.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Get the larger 8TB drive and juggle your games.
Steam has a feature where you can move a game from 1 drive to another, it makes it easy to cache games you don't play often onto your HDD, then just move them back over to your SSD when you want to play them, then move back when you need more space.
I struggled with a 240GB SSD for years using this method, a good option is getting a 2nd 240GB ($40 on Amazon, Kingston A400) and put it in raid 0 with your existing 240GB, it will give you 450GB total and 150% read speeds you were getting before.
SSDs are pretty reliable, but always make sure to have a backup. I'm sure you could dedicate a 480gb chunk of your 3TB spinning for a SSD backup.
For your low storage space, keep your documents/photos/downloads/pictures/music folders on your spinning storage (since none of that needs to be fast), you can right click on them, click properties and point to a folder on your non C drives for those shortcuts to point to. Also makes it really easy to reinstall windows since all of your files are already backed up :)
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
