COBOL logic issue
Solved by Matthew Waring,
On 12/21/2018 at 9:38 AM, Dat Guy said:Tried GO TO?
On 12/22/2018 at 12:03 AM, Tadiaush said:Hi!
after IF condition try to add GoBack.
but I would add a Flag indicator:
01 WS-if-correct-FLAG PIC X VALUE ‘T’.
88 WS-if-correct Pic x value ‘t’.
88 ws-if-correct-false pic x value ‘f’.
Then after the if condition set this flag to true - SET WS-IF-CORRECT TO TRUE
And with others if condition check this flag. (If you are not using else)
Hi guys, sorry for the late reply... been rather busy. I managed to fix it by using a GO TO which took me to the end of the section so that it would do not more processing.
