turn up the fan speeds with something like MSI Afterburner. In MSI Afterburner you can define a new fan curve which should help
Builds:
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097774
what kind of curve should i do? i dont want fans to work %100 all time, i intend to keep this system for at least 4-5 years :( i dont want fans to fail down the road. are they hard or expensive to replace?
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097778
you can replace the entire cooler with a better one from Arctic or someone else for fairly cheap and the times i have done it its been easy. As for what fan curve you should make, id recomend just raising the curve from ~40C and up a bit over stock
Builds:
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097783
thanks i will try that. are my case setup problemetic for the gpu temps? are there any improvements can be done in that aspect?
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097794
you could maybe add another fan but idk. that case seems like it should be pretty decent for GPU temps when i took a short look at it
Builds:
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097805
Run the fans at 100% and side panel off. That way you know before hand if it’s wven worth while to start throwing parts at it.
Airflow is a real problem in that case.
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12097963
Looks like most of the air from the one (at least that I could see) intake fan is going over the top of the GPU, so not much fresh air is being made available which would help explain the higher temps with the side panel off.
I have that same card and in demanding games with the stock MSI fan curve I see between 70-74 C (with 21 C ambient), so you're panel-off temps seem reasonable.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12098639
Jesus, what’s the fan speed at now?
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12098958
Put 100% for what you want the max temp to be. I use 100% for 79ºC o my GTX 1070. Your temp issues will be gone.
Manufactors put very low default rpms for a more silent operation.
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Seagate Barracauda 2TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
https://linustechtips.com/topic/1010210-gpu-temp-issue/#findComment-12099259
  • 2 weeks later...
