Help needed. USB Boot device issue.
Go to solution Solved by iamdarkyoshi,
You'll want the one that says UEFI. Other one is for legacy support.
Hi,
I'm installing Win 10 from a USB drive on my new system. I ran into this issue where my USB is displayed as 2 different 'Partitions' in the Bios. Which one do I pick for installation?
I used Windows creator tool in order to install boot files on clean USB.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1009956-help-needed-usb-boot-device-issue/
Do I put other one to the bottom of boot priority for the time being?
Shouldn't matter
24 minutes ago, iamdarkyoshi said:
Shouldn't matter
Sorry to bother you again. By some dark magic, I now have 2 boot options, how do I delete the one I don't need.
I already did the setup for main one.
Can you show an image of the two options? Is it just in the BIOS or when you turn the PC on?
When I boot into Windows
Did one of the drives previously contain an install of windows?
Yes, but I formatted it in the windows install.
You need to delete every partition until everything says unallocated space
