Randomly unable to load web pages
Solved by TheNerdyCanadian,
On 12/17/2018 at 12:37 AM, Skiiwee29 said:Usually thats a DNS issue. Find a website you cant load, open command prompt and type nslookup websitename.com and try and navigate to it via IP. if it opens via IP and not website name, then its a DNS issue and you likely need to change the DNS servers you are using on your router.
I tried getting a new IP, DNS refresh, etc. I ended up reinstalling windows and not installing the Intel LAN driver and haven't had an issue so far. I'm thinking the driver ASUS provides is bugged.
