Does anyone know how much power typical B450 motherboards consume? I have an ASUS Prime B450M-A/CSM board and was wondering what it's power consumption was.
Also, how many watts would 2 8GB sticks of ddr4 3200 memory consume? I assume for memory, it is very low and almost irrevelant.
https://linustechtips.com/topic/1009080-power-consumption/
over 90% of total power draw comes from CPU and GPU, motherboard will take 20-30W max, memory is 5-10W
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1009080-power-consumption/#findComment-12087216
So the another components like case fans and usb 2.0/3.0 devices take almost nothing? So a 550W PSU with this board and that memory paired with an OC'ed Ryzen 5 2600X (4.2ghz at 1.39/1.4v) and OC'ed EVGA GTX 970 SC ACX 2.0 (1350mhz base clock- 2003 memory clock) would still work very efficiently? I'm looking at a $50 Corsair CX550M Semi-Modular 80+ Bronze PSU.
Also, how much power would my SATA III ADATA SU800 3D NAND 1TB Solid State Drive consume?
https://linustechtips.com/topic/1009080-power-consumption/#findComment-12087223
Just add 100W to the sum of CPU and GPU power draw, unless you run a server with a ton of drives that's enough margin of error.
Desktop benching:
https://linustechtips.com/topic/1009080-power-consumption/#findComment-12087257
On idle your sitting at avg 125 wattage used.  When you game that goes near 300 wattage.  hope that helps
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1009080-power-consumption/#findComment-12087394
