Projector set-up help
Solved by fabafaba,
I'd drill a 60mm hole in the projector room side of the wall for something like this for your mouse and keyboard to plug wireless dongles or whatever else in
To get the USB cables for the grommet through the wall on the other side, as well as to have a passthrough for a displayport cable, use these
And I'd really reccomend using a displayport cable for the monitor. I don't know how long the cable will have to be, but HDMI likes to crap out beyond 5-6m while you can get 10-15m on DP.
