Linux as the host: KVM, VirtualBox
Linux as the guest: VirtualBox
Interested in Linux, SteamOS and Open-source applications? Go here
Gaming Rig - CPU: i5 3570k @ Stock | GPU: EVGA Geforce 560Ti 448 Core Classified Ultra | RAM: Mushkin Enhanced Blackline 8GB DDR3 1600 | SSD: Crucial M4 128GB | HDD: 3TB Seagate Barracuda, 1TB WD Caviar Black, 1TB Seagate Barracuda | Case: Antec Lanboy Air | KB: Corsair Vengeance K70 Cherry MX Blue | Mouse: Corsair Vengeance M95 | Headset: Steelseries Siberia V2
The best VM Linux OS is the OS you know how to use, they're all the same and you can strip them down if they are too big for your VM environment. Heck you can start with the Server Options of the installer and then add packages of what you need till you have your apps/environment setup and call it a day.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
Virtualbox is good for running desktop guest OSes on a desktop host OS but for hosting servers on a server, KVM makes more sense.
Docker is another than is starting get more attention and I'm probably going to be trying it soon. It is not full hardware virtualization but will allow you to run Linux in containers much like OpenVZ and LXC. It should be lighter on resources if you only need Linux VMs.
